99 s-10 auto trans won't shift
Old 11-19-2009, 04:42 PM
97fordguy970's Avatar
97fordguy970 is on a distinguished road
Default 99 s-10 auto trans won't shift
Hi, I just bought this 99 trailblazer it was in a minor accident but had to replace oilpan and motor mounts. But now it doesn't shift out of first, unless I put it in second, then it stays in second. Also the speedometer doesn't work. Any help is greatly appreciated. Thanks
Old 11-19-2009, 09:01 PM
I would bet your two issues are tied together. The VSS sensor is used to control both the speedometer and shifting. It will be on the tail housing of the transmission (2wd) or transfer case (4wd).
Are there any codes present?
Old 11-19-2009, 09:10 PM
No codes
Old 11-20-2009, 11:13 AM
does anybody know where the wires go from the VSS?
Old 11-21-2009, 02:09 PM
To the PCM...
96jimmy4door
11-09-2011 08:14 PM
Casole6
02-17-2011 12:01 PM
Tinted
35
02-07-2011 01:12 PM
Dennis The Menace
03-25-2009 08:41 AM
ccyne
03-20-2009 07:00 AM
Quick Reply: 99 s-10 auto trans won't shift
