vent hose leaking tranny fluid
my 97 4x4 s10 blazer has the 4l60E in it and as long as i dont drive it real far its fine but if i drive it more then 10 to 20 miles i start leaking tranny fluid from the vent hose and its a good leak to it gets on my motor and the exhaust and starts smoking i really want to figure out if this something i can fix or if i need to just go ahead and rebuild the tranny
check your transfer case for fluid level [top big nut on the back side of the case] - if its over full the front seal in the transfer case is bad and its getting fluid from the trans - transfer case on the two that i have vents up there and the trans just has a inch or two long metal vent at the top of the trans
Ok good to know thanks for the info hope that I can figure it out its been driving me crazy it shifts fine and everythang just I have to make sure to keep an eye on the fluid level in it and thats it
porkfriedrice
07-03-2013 02:51 AM
stereomike
09-19-2012 05:07 PM
86TransAm
14
12-13-2011 07:46 PM
