Can't Find Oil Pan Gasket That Fits
Old 10-05-2014, 02:58 PM
Clark Kent's Avatar
Clark Kent is on a distinguished road
Default Can't Find Oil Pan Gasket That Fits
I am building a 1986 K5. I dropped a 1980-1985 small block in it:
  • Casting # 14010207
  • 383 cubic inch displacement
  • 2-bolt rear main
  • Passenger-side dipstick
  • 2-piece rear main seal
My new oil pan fits well, but I can't find a gasket since I have a thin front seal. The tech guys at fel-pro tell me no gasket exists for this application. I find it hard to believe that a sbc with any configuration can't be fit with the correct gasket. Fel-pro's 1881 rubber gasket fits perfectly except for the front seal. Fel-pro's OS 5197 C-2 (used for pre-1980 sbc) has a thin front seal, but the bolt holes don't match. I want to use a 1-piece rubber gasket, but will settle for what I can find. Has anyone run in to this problem? Can anyone recommend a gasket that will fit?
Old 10-05-2014, 06:50 PM
rexazz2's Avatar
back in the day that probably never came as a one piece
Victor gaskets made a set called "tough cork"
Still a multi piece but the cork sides have a metal rib sandwiched in between layers of cork
I like a skim coat of Permatex #2 and a little dab where it transitions to rubber
If everything is clean for assembly you shouldnt have any seepage down the road
Old 10-14-2014, 07:31 PM
Clark Kent's Avatar
Default No rubber gasket
You're right. I can't find a rubber gasket so I went with an old-style 4-piece gasket. It fits good but will be a pain to clean up if I ever need to change it out.
marcspector
16
10-23-2015 09:26 AM
jaq62
15
06-24-2011 01:24 PM
kevin turner
04-09-2010 01:21 PM
AaronGene02
01-24-2010 11:38 AM
kakn
01-14-2007 01:18 PM
Quick Reply: Can't Find Oil Pan Gasket That Fits
