just became a blazer owner! any helpfull upgrades?
Old 11-28-2012, 06:03 PM
Aj Stachowicz's Avatar
Aj Stachowicz is on a distinguished road
Default just became a blazer owner! any helpfull upgrades?
hey guys, my wife just bought me an 87 k5 blazer. original .350 with 80,000 miles. can you think of any good performance parts or upgrades for it? the reason im askig is im on deployment in Guantanamo Bay, Cuba, and havent even driven my truck yet. and yes i am a blazer virgin. any input would be great. thanks guys!
Old 11-29-2012, 09:31 AM
70-K5's Avatar
70-K5 is on a distinguished road
Where to start...
What do you want to do with it? Mall-crawl, rock climbing, expedition, mudding.... lots of setups, lots of combinations that work for specific applications.
Old 11-30-2012, 01:32 PM
i want some performance and its mainly gonna be steet driven with a little off roading
Old 11-30-2012, 02:02 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
87,im guessing its fuel injected aka tbi? Google "ultimate tbi mods" and do it. makes a difference. put a quarter in the regulator,advance timing a few degrees,get exhaust done,drop in k&n filter,and maybe a mild cam and a tune.
Depends on how much money you wanna spend.
Old 12-03-2012, 09:41 AM
70-K5's Avatar
Not to nit-pic but *performance* is a relative term. Assuming that you mean 0-60 I don't know if you started with the right vehicle.
Your tbi motor is limited to about 250hp unless you're going to drop a bunch of cash into it. And at the point you start making serious HP you'll need to start replacing axle shafts and transfer case's.
The best thing I can suggest to improve performance is to take all the stuff you're carrying around and leave it in the garage. Get a soft top and save yourself a few hundred lbs off the back... every lb counts. The other upgrade would be to swap your gears. 3.73 is a common gear ratio to find in the rear end and depending on what size tires you're running you could lower the ratio (higher numerically) If you put some 4.56 gears in the rear end and then you'd be able to smoke the tires, is that the performance you're looking for?
Old 12-03-2012, 01:40 PM
LeWhite's Avatar
The best mod for that truck is to not raise it.
Old 12-08-2012, 10:54 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Couldn't agree more with this. Also some good things to do, either drop in K&N filter or CAI. Do the ultimate TBI mods, put in some ACDelco Rapdfire plugs, change wires, cap, rotor, fuel filter and you should be good to go.
Old 12-10-2012, 09:32 AM
70-K5's Avatar
I don't want to Hijack the OP's thread but why do you two suggest not to raise it?
SpadedJimmy
Performance & Brainstorming
08-31-2011 08:33 PM
BlazerGuy2001
09-17-2009 11:17 PM
TheBrettster
03-30-2008 05:12 PM
kpro89
16
02-09-2008 08:00 AM
99 Blazer 4x4
09-29-2007 09:01 PM
Quick Reply: just became a blazer owner! any helpfull upgrades?
