dyi alignment
Old 06-15-2013, 11:00 PM
98BazetasticGen2S10's Avatar
98BazetasticGen2S10 is on a distinguished road
Default dyi alignment
Ok, I'm new here but I've had my blazer for a while. I have a 98 s10 4x4 with 2" body lift and 2 1/2 suspension. I'm running on 30" bfg ko's. The alignment is set to 0° camber and 1° tow in. It doesn't feel right, pulls to the left, etc. Why is it supposed to be set to, suggestions?
Old 06-16-2013, 06:33 AM
newguy's Avatar
I do mine myself and do 0 camber and go with the front of the tires in 3/8s of an inch.
Old 06-18-2013, 10:16 PM
Baja Blazer 85's Avatar
Baja Blazer 85 is on a distinguished road
If it's pulling to either side (and you swear you have the alignment even) you may want to check your tie rod ends, ball joints, pitman arm, idler arm etc. Make sure there's no wiggle room or play.
Everything may look straight when the truck is parked, but at speed stresses are applied to all of these parts, which will cause them to move around.
blazen_red_4x4
10-13-2014 12:39 PM
Njudkins21
Suspension Tech
12-06-2006 05:40 PM
Walleye
Suspension Tech
02-26-2006 10:35 PM
ivannj
01-31-2006 11:30 PM
dblazer
08-24-2005 08:16 PM
Quick Reply: dyi alignment
