Automatic Lights
What year is your truck?
The 2nd Gens have automatic lights, you can keep them from automatically coming on by clicking the dome light button quickly four times. You will hear a chime and the headlights become manual.
This has to be done everytime you want to switch the lights over to manual.
I tried a search, even a tag search and I got nothing for auto headlight disable. Sorry guys, am I just incompetent with search?
Could someone just throw the link up here? Because this is the thread it kept giving me.
To disable ahl all you have to do is take out the passenger side speaker grill and if you car is 2000+ then unplug the sensor and put a 2.2k ohm resistor into the plug.
Heres links to the guides. (I just installed hids on high and low, relay to disable dhl and enable quad beams and disabled ahl. )
http://www.zr2usa.com/mboard/index.p...hreaded&start=
Different. DRL's are only daytime running lights and do not turn on your parking lights. Auto-headlights turn on everything when the ambient light level drops below the preset level (whatever that is). Defeating the DRL's will not keep the lights from coming on at night.
If you can, I would just do the quick defeat using the dome override button.
and as far as i know, we have to pull the fuse for the DRL's if we put in a HID system.
http://www.zr2usa.com/mboard/index.php?showtopic=6098&pid=182196&mode=threaded& start=
i'll post a link when i find it.
Mine is a 99. Where would I find a resistor for this application? Is Radio shack or some place like that the place to go?
yeah, Radio Shack was the place mentioned to get that resistor.
Ricksastar
04-24-2005 07:05 PM
