Fog light question.
Fog light question.
Well, I've decided I want to wire up some fog lights behind my grille (when is the question now, winter is coming so...) to have a clean look, while maintaining functionality.
My question is, after searching I figure getting power straight from the battery is acceptable (I'd put an in-line fuse in just in case). Would I need a relay? And if yes, what size/rating would I need? (This coming from the quad beam mod kit I remember seeing that had a relay.)
Any other info or tips would be appreciated.
Thanks.
Thanks.
I don't see why you'd need a relay. I guess it would depend on the lights you get.
Open mouth insert foot.
Shouldn't have said anything. lol....but after a little searching I thinks these issues are going to impact your decision.
Are you wiring straight to headlight switch? What's the amp draw on your fogs? Link.
That's interesting. Thanks.
i would definitly wire in a fuse relay.
Chances are the fog light wiring is already there. Look under the hood at your fuse box and see if you have a relay and fuse in there. All you would need to buy is the headlight switch box with the fog switch in it, for a clean look. the wires for the lights will be behind the grille.
I know this is old..but if all you need is the headlight switch for fogs..what about wiring to the fog lights is that there too? to hook up the switch i mean
I'm adding aftermarket fog lights but I'll probably pony up the money and have the BCM programmed for factory fogs sometime, too.
Wow... anyway, I'm getting a custom light bar made and I'm going to wire fog lights up on that, and Driving lights behind my grille... I'll make a diamond plate light switch plate and put that somewhere.
shortandlong
10-03-2008 07:29 AM
