Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Cut front springs
Old 05-28-2016, 08:33 PM
bthornburg's Avatar
bthornburg is on a distinguished road
Default Cut front springs
I want to lower the front end of my 2003 Blazer Xtreme. Question i want to lower 1". How much spring needs to be cut to acheive this. I don't want to install drop spindles. Also would i need new shocks once lowered
Old 05-29-2016, 12:00 AM
LeWhite's Avatar
There is a 2:1 ratio because the spring is half way to the lbj. The spring wire is roughly 1/2 inch dia. When the spring is installed the ends are almost coil bound. To answer the question about one third to one half turn might be right. You should not need new shocks unless you drastically cut the bump stops.Xtreme shocks are already shorter than normal . Hint: don't use a cuttimg torch.
S10Blazerdude
Lowering Tech
05-01-2010 07:56 PM
greg3000
15
02-27-2010 08:57 PM
dsrp
01-12-2010 03:48 AM
Big E
Suspension Tech
02-12-2009 08:25 PM
lt170chevelle
Lifting Tech
09-25-2008 04:19 PM
Quick Reply: Cut front springs
