Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
adding window controls
Old 11-22-2014, 05:26 PM
Chad Plumadore's Avatar
Chad Plumadore is on a distinguished road
Default adding window controls
I am disabled from birth missing most of my right leg, part of my left arm and a few fingers. I have difficulty using the window controls where they are and was considering adding a set in the arm rest console in the middle of the seats. My question is if they would even work after I ran the wires to splice into the existing door controls?
Old 11-22-2014, 06:48 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
As long as you match the positive and negative wires then you should have no problem with them working. And if you're really unsure about it then hook some wires to the new switch you are going to use and test it before you fully run the new wires.
Old 11-23-2014, 10:32 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
The way I would do this is just splice in some extra wires to make the OEM harness that plugs into the OEM switch long enough to make it to the center console and mount it.
Old 11-27-2014, 01:21 PM
El_Beautor's Avatar
This is what I'd do too. Just extend the whole harness and use the OEM switch so that you know it will work properly.
stlfish
09-22-2009 05:27 PM
brokenfish
12-08-2008 09:49 PM
bluesjam99
02-17-2007 03:34 AM
hootymo
01-20-2007 05:08 PM
mrbill531
09-12-2006 12:56 AM
Quick Reply: adding window controls
