Passenger window controls
Old Sep 18, 2009 | 07:21 PM
stlfish's Avatar
stlfish is on a distinguished road
Default Passenger window controls
I had some speakers installed in my 2001 Blazer LT 4 Door, and now the window controls on all of the passenger doors don't work the windows. I removed the panels and checked all connections but everything looks OK. The widow lock is not on and I can control everything fine from the drivers door but not passengers. However when operating from the drivers side and pressing a passenger control it stops the window operation. What could be causing this? Whats next? Also, I can work the locks just fine.
Old Sep 18, 2009 | 09:56 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
If you push a button on the drivers controls and it stops a passenger window that's normal (passenger switches work only if drivers are at rest position) If they all worked before then recheck the 4 pin connector 2nd from the front on drivers side - passenger window lockout switch. If it's snapped in correctly look closely at your connectors to see if a wire walked back out of the connector. If all the wires look to be good pull the 4 wire connector out of the drivers lockout control and jump the dark blue to the dark green with a piece of wire, this is like turning the lock off. If that works the lockout switch is bad.
Old Sep 22, 2009 | 05:09 PM
stlfish's Avatar
Default jumped it and it worked
Bad lockout switch going to pick one from another. Thanks for the tip
Old Sep 22, 2009 | 05:27 PM
Beverly Stayart's Avatar
Beverly Stayart is on a distinguished road
Thanks for this helpful info.
Chad Plumadore
Performance & Brainstorming
Nov 27, 2014 01:21 PM
brokenfish
Dec 8, 2008 09:49 PM
aaronjohn20
Mar 20, 2008 12:51 PM
bowanna03
Jan 8, 2007 11:23 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
