Fuel pressure Regulater
Old Oct 9, 2008 | 06:55 PM
banshee386's Avatar
banshee386 is an unknown quantity at this point
Default Fuel pressure Regulater
Can i replace the fuel pressure regulater on a 95 blazer vin w its leaking on my spider injecter i tried taking the regulater off useing a torx bit but the bolt has a raised center to it that wont let the bit go in any idea's i really dont wanna spend a few hundred right now on a new spider injecter
Old Oct 9, 2008 | 07:06 PM
whitezombie198's Avatar
whitezombie198 is an unknown quantity at this point
Default RE: Fuel pressure Regulater
You can get them from advance auto for $44. When I bought one, it came the bit and o-ring. Its from motormite part number 55162
Old Oct 9, 2008 | 07:19 PM
You need a safety torx bit to remove the screws holding the FPR in.
Old Oct 9, 2008 | 07:29 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
I was able to remove mine by gripping it with a pair of plyers the screws are not very tight or you can get a bit set from Harbor Freight pretty cheep
Old Oct 9, 2008 | 07:34 PM
Leeann_Bravada's Avatar
I got the FPR from AutoZone - it's a Dorman/Help! part - and it came with the security torx bit.
Old Oct 9, 2008 | 08:20 PM
banshee386's Avatar
cool thanks alot besides the regulator and the nut kit what other parts might i want to consider checking for leaks like i said money be a little tight right now thanks
Old Oct 9, 2008 | 08:23 PM
That would be the extent of it unless the individual fuel lines out to the poppet nozzles were leaking.
Check out Lindertech.com. They have a kit that adapts the newer, more robust FPR from the 96+ engines for use in the CPI spider. Only requires a bit of modification to the CPI injector body.
Old Sep 7, 2009 | 12:02 PM
bigdaddykane93's Avatar
i have to check my spider or regulator too because i found a little bit of fuel at the bottom of the intake. any tips on where exactly to look? thanks
brianroark
Jun 25, 2010 03:14 PM
Spartan66
Jul 11, 2008 02:34 PM
riverjamie
Sep 24, 2007 08:21 PM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
