lift help/advice
Old Nov 9, 2009 | 08:40 PM
xc2strokestomper's Avatar
xc2strokestomper is on a distinguished road
Default lift help/advice
im looking for a little bit of a lift and soem bigger tires. a budget build would be the best. ive been looking around and it seems like a body lift and shackles with the t bar would be the easiest? and cheapest? i dont want anymore than 4 inches. i just want a little more aggressive look to it. maybe a 2 inch body lift? with 31's? anyone have any suggestions on what to do for a 3 or 4 inch lift total?
also i would like to try some wheel spacers to help with the handling once its lifted. what size spacers do people usually use? 2 inch?
thanks guys
Old Nov 9, 2009 | 08:53 PM
NVANZEE's Avatar
do exactly what you said and you will fit 31s. If you get spacers dont get cheap ones they will break. Also with spacers you wont be able to use 31s unless you want to do some cutting. The farthew the wheels stick out the smaller the tire you can fit.
Old Nov 9, 2009 | 08:56 PM
maybe get a wider wheel/tire rather than wheel spacers then?
Old Dec 6, 2009 | 05:58 AM
coivabs09's Avatar
Banned
coivabs09 is on a distinguished road
I never noticed this thread. Did you get it finished? Whats the brand of your lift? Did you try contacting the company for help?
BlazerGuy2001
Lifting Tech
13
Feb 20, 2010 03:55 PM
03blazertucker
Lifting Tech
Feb 10, 2010 07:24 PM
redblazer
Suspension Tech
Jan 4, 2007 02:20 PM
offroadin00blazer
Suspension Tech
15
Sep 13, 2006 09:34 PM
boomtruck97
Suspension Tech
Jun 29, 2006 11:01 PM
