1997 4x4 blazer remove front axle?
Old Aug 16, 2010 | 03:02 PM
jorg's Avatar
jorg is on a distinguished road
Question 1997 4x4 blazer remove front axle?
I have an vibration in my 1997 4x4 blazer....
I have just a week ago replaced the rear wheel bearings....but still vibration..
The vibration I feel in my feet at the driver side...
Now for a check I want to remove the front axle and make a test drive,because I think he's making the noise/vibration(U joint's or something)
question 1: can I drive without that axle ?I mean is it worse to drive with my front differential disconected from the transmission?
question 2: how do you remove the axle? I have try it with the 4 bolts loose but there is't enough space to get him out....
see photo
Old Aug 20, 2010 | 05:12 AM
jorg's Avatar
nobody
Old Aug 20, 2010 | 06:26 AM
You can drive with the front axle shaft removed. You remove it by first unbolting it from the transfer case, then unbolting it from the front axle. It will come out.
Old Aug 20, 2010 | 06:09 PM
jorg's Avatar
thanx for the answer
When I remove the driveshaft at the tranny side....there is a rubber boot...is that difficult to remove? or just remove the iron ring that's hold it?
Old Aug 22, 2010 | 03:47 PM
Actually, you may have to just pull out the driveshaft from the front of the transfer case. It may take a little prying, but I forgot that the smaller trucks are splined into the front of the transfer case.
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
dannyb91979
Feb 24, 2012 09:17 AM
cutthroatxxx
Mar 28, 2011 09:07 PM
99blazerman
Jan 24, 2010 11:45 AM
