Axle Seal needs replacing, help
Old 10-27-2007, 10:18 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default Axle Seal needs replacing, help
Hey guys,
I am posting this as I can tell that my front passenger side axle seal is leaking between the inner cv shaft and the solid axle tube that runs to the front differential. I am wondering how hard/expensive it would be to do this job myself, or if it is worth it to take it to the shop. Also if anyone has some detailed directions on how to do this job I would love to see them. Thanks in advance, my truck info is in the signature.
Old 10-27-2007, 11:37 PM
Chevy Lover's Avatar
Default RE: Axle Seal needs replacing, help
Are you talking about this (looks like probably #2 in the diagram)?
Old 10-28-2007, 04:17 PM
I am not sure if it is the #2 item on that pic or what it is. I just know that it is leaking out of where the Passenger side CV shaft meets that solid axle extension. I was not able to find any good info on this problem in the hayne or chilton manuals I have and am not sure how much work it will be to replace it. I am thinking I might just go to the shop on this one, I am atleast going to call them up on monday to see what it would cost / what the actual bad part is.
Old 10-28-2007, 04:59 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
i replaced mine on the same side. it was easy, of course i already had my suspension tore apart to do the balljoints. so if youre JUST doing the seal, its probably a pain but if you maintenance to do to the suspension its easy
Old 10-28-2007, 06:26 PM
Yeah I just replaced the balljoints and then this started to happen, so I dont really want to pull all that apart again, but I may end up doing it if it saves $400 or more (which it probably will).
RunninWild
10-17-2013 08:45 PM
ruben6805
05-06-2012 09:00 PM
deedub711
04-19-2011 09:11 PM
litterbug
03-07-2011 09:14 PM
tmoble
06-15-2009 09:39 PM
Quick Reply: Axle Seal needs replacing, help
