Right Front Squeak
Old Oct 17, 2007 | 07:30 PM
Maynard97's Avatar
Maynard97 is an unknown quantity at this point
Default Right Front Squeak
Hello,
I'm new to the group and I have a problem. I have a '97 LS 4WD Blazer that has a very annoying squeak in the area of the right front suspension. It sounds almost like rubber or a very squeaky spring. I can replicate the noise by pushing down on the right front bumper. I see some grease zerts in the area - is it possible it just needs some grease? I love the vehicle - I bought it the day I met my wife and I'd like to keep them both for awhile! Any advice would be appreciated!
Thanks,
Maynard
Old Oct 17, 2007 | 07:37 PM
Default RE: Right Front Squeak
Its quite possible that the bushings have dried out. Take some WD40 and spray down one bushing at a time seeing if the noise goes away. I would start with the bushings on the sway bar where the sway bar is attached to the frame. Then move on to where the upper and lower a-arm attach to the frame.
Old Oct 17, 2007 | 07:39 PM
BigGreenMonster's Avatar
BigGreenMonster is an unknown quantity at this point
Maynard James Keenan??? Could need a lube job, could also be ball joints, shocks, worn out bushings, etc... Without sticking my head under it, thats the best advice I can give.
Old Oct 17, 2007 | 07:43 PM
88jimmah's Avatar
88jimmah is an unknown quantity at this point
Shoot all the bushings up front with some silicone lube spray and it should stop it
http://en.wikipedia.org/wiki/Silicone_grease
Old Oct 17, 2007 | 07:46 PM
Yup, silicone is the long term fix!
Old Oct 17, 2007 | 07:52 PM
ORIGINAL: swartlkk
Wait, I thought that was duct tape???? At least thats what the T-shirt says.
Old Oct 20, 2007 | 11:59 PM
Johnkoch's Avatar
Johnkoch is an unknown quantity at this point
Maybe balljoints thats what i would check,it sucks when u wait off and one seperates while your driving and your tire folds in,I would know this it happened to me
Old Oct 28, 2007 | 07:56 PM
Maynard97's Avatar
Thanks! I finally got around to trying it and the silicone spray did the trick. Maynard
94s10blazin
Sep 24, 2018 10:38 AM
WickedBlazer
Sep 12, 2012 03:14 AM
Green87S10
Jan 9, 2012 06:43 PM
thrash902
Sep 15, 2010 10:52 PM
cbetmark
Jun 30, 2007 07:09 PM
