Rattle at 35 mph
Old 03-22-2017, 06:59 PM
broark2017's Avatar
broark2017 is on a distinguished road
Default Rattle at 35 mph
I have searched My 2000 blazer LT 4x4 over for this rattle and I cannot find it. From 0-30 mph no noise , from 35-45 (sometimes a little higher) I get this rattle from sounds like passenger fender area.. Usually above 50 I hear nothing. I have taken everything off the inner fender from the blower motor to the headlights .. including the blower motor itself (needed changed) . The PCM had some up and down movement so when I put everything back together I put some rubber under it ..Wasn't the noise it is still there. I have replaced the whole front end except the control arms . New ball joints, tie rods, idler, hub assemblies cv axles, brakes, rotors sway bar bushings, links. New shackles , shocks , calipers, brakes on the back and new brake line from front to back. I also did the hood hinge fix .. What on earth am I missing to stop this annoying rattle ?
Old 03-23-2017, 04:01 PM
Stumpalump's Avatar
Stumpalump is on a distinguished road
Break pads rattle. Lightly touch the break pedal when you hear the noise. If it stops....
Old 03-23-2017, 06:37 PM
broark2017's Avatar
Not the brakes .. It makes the noise braking, accelerating, turning, up hill, down hill ... I haven't tried a wheelie or 2 wheels yet but every other way the noise does not change. I noticed today that occasionally I can hear it a interstate speeds as well . I thought this morning I found the problem the bottom bolt at the back of the passenger tire on the inner fender well was loose . The big washer would spin and rattle .. tightened it.. didn't help. I'm off work the next 2 days ..some serious searching gonna happen.
meatbag
09-24-2012 10:26 PM
JAS69
11-20-2009 09:12 AM
woodsballr
04-19-2007 12:12 PM
joey
02-19-2007 03:50 AM
syrblitz19
06-17-2006 09:13 AM
Quick Reply: Rattle at 35 mph
