Replacing ball joint.
Old 08-04-2010, 09:52 AM
rockrodent's Avatar
rockrodent is an unknown quantity at this point
Default Replacing ball joint.
Hey all, just had a quick question.
I'm getting ready to replace my passenger side lower ball joint. Now, the part I bought is the ball joint loaded into a top plate with a hole cut out for the grease nipple. The write-up in the tech articles was helpful for the removal of the ball joint, but I wanted to know if after it's all removed if I need to "press" the ball joint into place, or if the plate that the ball joint came with is the part it needs to be pressed into. If so, I'd imagine I need a ball joint press, no? Or am I overthinking this and it just needs to be bolted into the old rivet holes?
Old 08-04-2010, 11:16 AM
mr.vls's Avatar
mr.vls will become famous soon enough
Upper ball joint is bolted where the rivets were, lower ball joint is removed and installed with a ball joint press.
Old 08-04-2010, 05:32 PM
What's the vehicle we are talking about here...? Please always provide your vehicle information. From your other posts, I can see that you have a 2003 4wd truck. Both the upper and lower ball joints are riveted in stock and replacements will bolt in.
Old 08-04-2010, 08:16 PM
rockrodent's Avatar
Duly noted
josemateos
02-18-2014 10:00 AM
porkfriedrice
27
07-06-2012 08:03 PM
Guntheone
12-04-2010 05:59 PM
timetoblaze
04-17-2006 12:47 PM
00ZR2BLZRGUY
Suspension Tech
01-01-2006 08:12 PM
Quick Reply: Replacing ball joint.
