8 inch wide rim with 3.75 inch back space. will these fit on a zr2?
ive done some messuring and im sure they will fit but im looking to see if anyone else has the same set up or one thats close to this so i can look and see how far they stick out? i'll be running 33x12.50x15's. if you have a similar set up or one that is exactly the same can u post a picture so i can get an idea of what they will look like? thanks any help would be great!
that is probably going to rub. your rims will stick out 3.25 inches more than your stock rims. how much of a lift do you have on your zr2?
2 inch shackle lift and a tbar crank plus ive already completely gotten rid of the front valence and done some trimming with a sawzaw to the rear of the rear wheel well. i'll be getting some replacement leafs in the rear as well to help the sagging that has occured with 150k of hard driving. im also willing to more trimming if nescecary...... saw is in hand haha..
Plan on cutting away your entire rear inner fender up front and cutting on your rear flares. Might even have to hack into the bumper if you ever plan on turning. And forget about ever going offroad.
I've got a 2" body lift, 2" shackles and the tbar tweaked and still rub when offroad with max flex while turning. This is with 33X10.5's on the stock rims. Yep, need to to a bit more trimming myself.
yea... thats a lot of trimming
haha i guess we'll see how much i really need to trim..... will post pictures when its complete. ive seen trucks with 32's and no lift! no shackle no tweak! the fit with room to spare and no rub that i can see.... i will have to inquire with the owner to see how bad if any rub there is while off road..... also i do have a zr2 which is higher than a stock blazer idk if that had been taken into account...? im only going with two inches larger on the tires and have gone 3-3,1/2 inches higher with the truck so far.
Ajbert has a zr2. I'm rubbing with 31's and a 2 inch lift
Spectreblazer
02-13-2010 04:59 PM
