2 wheel drive rims alloy
Old 09-27-2008, 07:35 PM
pjftmd107's Avatar
pjftmd107 is an unknown quantity at this point
Default 2 wheel drive rims alloy
I just need to know what year alloy rims will fit on my 83 s10 2wd. i bought a set of four off craigslist the bolt pattern and offset it correct but the center hub will not fit. mine are to big. i really want a set of chevy stock alloy rims will the ones off a 4wd fit??
Old 09-28-2008, 09:53 AM
Ash's Avatar
Ash
Ash is offline
Ash is an unknown quantity at this point
Default RE: 2 wheel drive rims alloy
Quite sure the bolt pattern is the same, but offset is where you are really going to hurt. 4WD rims have an offset around +35mm because of the axles. This means they will sit too far in and cause rubbing issues on your 2WD. You can use 5x120.65mm-5x120.65mm adapters to push them back out, but I don't know how sturdy that will be. There is a lot of controversy on the use of such techniques.....
Best thing you can do is find someone experienced with that particular switch and see what they had luck with. The adapters are not cheap by far. Starting at $100+ for all wheels I believe for cheap quality ones. Checkout some wheel replica companies to see what they offer. That may be even better.
mirrorimij
06-08-2019 03:34 PM
racsan
Tires and Wheels
34
04-07-2015 04:41 AM
rexazz2
Tires and Wheels
11-21-2013 04:10 PM
gstrat323
Tires and Wheels
04-22-2008 08:35 PM
Ernie1019
03-09-2006 12:53 AM
Quick Reply: 2 wheel drive rims alloy
