4.3 radiator help
Old 06-07-2009, 03:37 PM
82 Iron Duke's Avatar
82 Iron Duke is on a distinguished road
Default 4.3 radiator help
Hello fellows, it never fails you fix something and something else breaks. Long story short, I just replaced the rad drain plug/**** and there is what looks a shaft underneath where the plug screws into. Is there supposed to be a hose attached or should there be a plug for there also?
Thanks, I have searched and found nothing.
Old 06-07-2009, 04:21 PM
Answered in the older thread you posted in.
No, nothing is supposed to be connected. If coolant is coming out of the nipple, the valve is not closed all the way.
Old 06-07-2009, 05:20 PM
Thanks again, I feel like a schmuck
Old 06-07-2009, 07:03 PM
Thanks for all your help swartlkk, I appreciate it. Heres is one thing I was wondering about, the drain plug is plastic and it broke on the **** so the rest of the plug stayed inside the rad. I tried to remove it without having to take the rad out so it broke and fell inside the rad. It's not that big of a piece, do you think I could have any problems down the road with that piece being in the rad?
Old 06-07-2009, 07:34 PM
It is likely that it would be sucked into the engine where it may cause problems with either the pump or the thermostat. If it were on the driver side of the radiator, I would say do not worry about it.
Old 06-07-2009, 07:53 PM
It is on the drivers side, thanks, now I can sleep a little better.
Old 06-07-2009, 09:15 PM
Drain plug on the driver side...?
Old 06-08-2009, 07:10 PM
Yes, it's a 94 Bravada and the drain plug is infact on the drivers side. She ran fine today, no problems.
Old 06-08-2009, 10:58 PM
Well, that would explain it.. No reference to what it was you were driving and I was just thinking of the later 2nd gens.
bigdaddykane93
01-04-2010 12:03 PM
Ayieka
05-16-2009 08:34 PM
afrench690
15
04-17-2008 05:46 PM
Maldo15d
12-04-2007 08:00 PM
Hanr3
Engine & Internal
09-08-2006 02:31 AM
Quick Reply: 4.3 radiator help
