91 blazer stalls after long idle
I recently moved from Calif to Michigan my blazer runs fine, but after a long idle it coughs and hesitates when accelerating. Runs fine unless I sit at idle after warmed up i.e. drive thru at McDonalds, bank ect. So where do I start?
RE: 91 blazer stalls after long idle
Possibly exhaust system, or EGR system. Mine codes the o2 sensor running lean after a long idle. Do you get any codes?
Sounds as though it is loading up with fuel... Have you checked for a fuel leak around the injectors (this is a TBI motor correct?)? How about a vacuum leak at the base of the throttle body? Possibly a partially clogged IAC passage/valve (I think the TBI motors had an IAC valve anyway)?
I'll throw 20 bucks on the timing being off a tad, Had the same problem with my 86 s10 pickup. Get a mechanic to throw a timing light on it
cide
05-04-2009 02:23 PM
gnpower
15
04-20-2009 12:48 AM
richard5294589
12-23-2006 01:03 AM
see119
08-30-2005 02:00 PM
