94 S-10 Blazer: Gas Gauge problem and gas leaking
Old 09-22-2010, 01:02 PM
starandrose's Avatar
starandrose is on a distinguished road
Default 94 S-10 Blazer: Gas Gauge problem and gas leaking
I have a 1994 S-10 Blazer (v6 - vortec i think) I just bought it and the gas gauge does not work...anyone know why or how I can fix it? Also, when I fill up my tank, if i add even 5 cents extra than full, a whole lot of gas spills out from the gas tank, i think around the passenger side...does that mean there is a hole in my tank? or is there some kind of over flow? please, someone help!!!!!
Old 09-22-2010, 01:47 PM
mr.vls's Avatar
mr.vls will become famous soon enough
The Gas Gauge connector is by the rear bumber, unplug it and the gage should read full with the key on engine off. If it does not more than likely you have a short to ground or a faulty gauge. If you have a U-Pull It junkyard removing the dash cluster is not hard and you can get a junk yard gauge for cheap and try it out. I just had a faulty oil pressure gauge that I got one from the junkyard for less than 5.00. On yours though the gas gauge might me tied together with the speedometor.
Old 09-22-2010, 06:25 PM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
Your cluster could be going bad, but try and check the connections, like suggested above.
Now with the gas leaking out, it sounds like your tank may be rusting out. I would get underneath the truck and remove the plastic housing and feel around the tank where you think its leaking from. See if you can feel a hole or something.
Gary MusicMan
05-02-2015 01:17 PM
er0ck273
09-01-2013 11:45 AM
grayman63
07-17-2013 01:56 PM
98blazerb
06-20-2012 09:53 PM
Mulisha
03-24-2008 09:14 PM
Quick Reply: 94 S-10 Blazer: Gas Gauge problem and gas leaking
