$200 offered to whoever can fix this rough idle bull ****
Old Feb 9, 2010 | 09:16 AM
  #21
It should be fairly steady, but if the input voltage and/or ground are fluctuating at all, it could cause a bad reading from the sensor. You could test continuity to ground or connect the positive lead to the battery and the negative lead back probed to the negative wire on the TPS. Do the same on the +5V reference to see if it waivers at all during testing.
Old Feb 9, 2010 | 02:20 PM
  #22
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Why dont you try reinstalling your egr?
Old Feb 9, 2010 | 05:10 PM
  #23
00bluegtp's Avatar
00bluegtp is on a distinguished road
Well I got a tps from advance and it was reading .8 volts at idle soo I had to slot the holes in it so I got just around .50. It runs like a champ and has incredible power now. It must have been running tooo rich before. I am going to see if that fixed it because I am going tobe plowing with the thing for the next 24hrs or soo. Ill let you know if its fixed because every other time i thought it was fixed it all of a sudden got screwed up again. But think for sure that was it. I have a feeling I could maybe go a little further down with t to like maybe .45 or soo but i didn't want to go tooo lean.
Old Feb 9, 2010 | 05:14 PM
  #24
Good luck! Let us know!
Old Feb 9, 2010 | 07:20 PM
  #25
04CVLXsport's Avatar
04CVLXsport is on a distinguished road
If it happens again, check your brake booster, even if the truck idles poorly , you should still have reserve vac left in the booster to work the brakes. But if the diaphram is bad in the booster, it would be a big vac leak and cause the loss of assist.
Old Feb 9, 2010 | 07:28 PM
  #26
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
sounds to me like someone owes you 200 kyle.
Old Feb 10, 2010 | 12:11 AM
  #27
00bluegtp's Avatar
Sorry it started doing it again. I happened to check the injector harness by tugging on it was running and it started doing the rough idle again. Im guessing the injector harness is bad. but im not sure.
Old Feb 10, 2010 | 06:31 AM
  #28
That harness isn't too bad to replace. The contacts in the connector on the injector get weak and do not properly energize the injector in some instances. Sounds like something may be pulling on that harness when you are driving backwards...
DimeBlazr
Jun 10, 2015 08:26 PM
chris015
Feb 23, 2012 09:49 AM
chris015
Oct 28, 2011 03:27 AM
spankyy
Performance & Brainstorming
22
Apr 21, 2009 06:49 PM
dirtyzr2
Aug 8, 2007 08:27 PM
