`93 4x4 Question
Old Jun 2, 2010 | 11:46 AM
bartele's Avatar
bartele is on a distinguished road
Default `93 4x4 Question
in my `93 4x4 The 4x4 works, but there is an extreme pull to the right, has anyone else experienced this, any suggestions on what to check?
Thanks!
Old Jun 2, 2010 | 11:47 AM
Is the pull only when you are engaged in 4wd?
Are your tires all the same size and properly inflated?
Old Jun 2, 2010 | 12:18 PM
bartele's Avatar
There is a slight pull to the right when not engaged, barely noticable, but present. I actually noticed this with the 4x4 engaged, before it appeared in the 2wd mode.
Tires are all the same size and properly inflated.
I did just notice the shock on the front right side appears to be leaking and possibly failing, could this be causing the issue?
Old Jun 2, 2010 | 06:56 PM
Its doubtful that the shock is the cause. They don't support the truck, just dampen the suspension so you don't bounce all over the place.
When was the last time the alignment was checked?
Old Jun 2, 2010 | 07:35 PM
bartele's Avatar
It's probably been a while .. I'm having some sloppy steering issues now too, I may end up replacing some of the front end and have not wanted to do the alignment just yet...
I just purchased this truck in march, I believe it had been left sitting for a while.
Athlon2012
Dec 16, 2014 11:35 PM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
