1987 S10 Blazer still won't run
Old May 31, 2010 | 04:43 PM
pbrew's Avatar
pbrew is an unknown quantity at this point
Default 1987 S10 Blazer still won't run
No spark from distributor to coil. I have fuel to throttle body, but no fuel at nozzles. I replaced the coil, and module in distributor. I cranked engine and noticed rotor was not turning, I pulled dist. the gear on bottom of shaft looks ok. Does anyone have an idea what can I check now. Paul
Old May 31, 2010 | 04:45 PM
abig84's Avatar
If the distributor isn't turning and its all the way in your timing chain broke
Old May 31, 2010 | 08:26 PM
ohsofly's Avatar
Yup, stick your stethoscope on and touch a valve cover or timing cover and listen for the valvetrain moving. If its not ticking away in there, and the distributor is not turning, then you most certainly broke a timing chain or cam or stripped the gear. That would really suck. Your engine also wont be sucking through the throttlebody when the valves arent working.
Old Jun 1, 2010 | 12:36 AM
pbrew's Avatar
Default 87 blazer
Thanks for the info, i'll start looking into the timing chain.
Becky Bartlett
Jul 12, 2015 09:06 AM
m3dragon
Feb 24, 2015 10:04 AM
jheth71
Nov 13, 2013 03:42 PM
pbrew
Jul 22, 2010 09:57 PM
pablo4429
Dec 22, 2007 09:59 PM
