1987 S10 Blazer still won't run
No spark from distributor to coil. I have fuel to throttle body, but no fuel at nozzles. I replaced the coil, and module in distributor. I cranked engine and noticed rotor was not turning, I pulled dist. the gear on bottom of shaft looks ok. Does anyone have an idea what can I check now. Paul
Yup, stick your stethoscope on and touch a valve cover or timing cover and listen for the valvetrain moving. If its not ticking away in there, and the distributor is not turning, then you most certainly broke a timing chain or cam or stripped the gear. That would really suck. Your engine also wont be sucking through the throttlebody when the valves arent working.
Becky Bartlett
Jul 12, 2015 09:06 AM
jheth71
Nov 13, 2013 03:42 PM
pbrew
Jul 22, 2010 09:57 PM
pablo4429
Dec 22, 2007 09:59 PM
