1987 S10 Blazer still won't run
Old Jul 11, 2010 | 03:59 PM
pbrew's Avatar
pbrew is an unknown quantity at this point
Default 1987 S10 Blazer still won't run
I installed new timing chain, sprockets, and chain dampner. I have spark and fuel at injecters at throtle body. I tried turning it over befor re-installing cover, water pump, and it still won't fire. I lined up timing marks as best I could. any suggestions. Paul
Old Jul 13, 2010 | 01:20 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Sure you're on No. 1 and not No. 4?
Old Jul 13, 2010 | 08:26 PM
pbrew's Avatar
it's possible i put the distributor back in wrong, I lined up the timing marks befor I installed the new chain and sprockets. A freind suggested I pull the number one plug and put a rag in the hole and crank the engine till the compression blows it out to find compression stroke and than pull dist. cap and see which cylinder is lined up with the rotor tab, and go fromthere. Paul
Old Jul 13, 2010 | 08:53 PM
ohsofly's Avatar
thats how its done, i just stick a finger over not into the plug hole, but the rag would work too i guess,
Old Jul 15, 2010 | 01:11 AM
You know that the marks will line up on No. 4 as well as No. 1? What engine do you have? I am guessing a 2.8L, right?
Old Jul 16, 2010 | 05:00 PM
pbrew's Avatar
Right, 2.8L
Old Jul 17, 2010 | 01:28 AM
You needed to have the engine at No. 1 cylinder TDC and the valves to No.1 both closed (cam in correct position) and then line up the marks on the crank and cam. Did you do this? If not you may have the cam and crank out of sync. The easiest way to check this is to put No. 1 piston at TDC and pull the valve cover and check if both valves are closed on No. 1. Don't know your level of experience with engine buildup so I'm not trying to be insulting.
Old Jul 22, 2010 | 09:57 PM
pbrew's Avatar
Thanks for all the help. After I found the compression stroke for the #1 cylinder, I pulled the distributor cap off again. The rotor was pointing to next cylinder. I pulled the distributor out again and set the rotor back to #1 cyl. put dist. back on and it fired right up and ran. Just have to get a new harmonic balancer and I can wrap everthing up and check with timing light. Thanks again, Paul
Becky Bartlett
Jul 12, 2015 09:06 AM
m3dragon
Feb 24, 2015 10:04 AM
jheth71
Nov 13, 2013 03:42 PM
pbrew
Jun 1, 2010 12:36 AM
pablo4429
Dec 22, 2007 09:59 PM
