1990 Blazer starts, drives then dies.
Old Apr 20, 2012 | 11:48 PM
rustyiron's Avatar
rustyiron is on a distinguished road
Default 1990 Blazer starts, drives then dies.
Truck starts beautifully. I can be driving along for 5-10 minutes just fine, but hit a big bump, and it dies. When it dies, it just won't turn over. We've had to leave it a few times, and whenever we go back to try again, it starts up just fine, runs beautifully for 5-10 minutes, then dies again. Any thoughts?
Old Apr 21, 2012 | 12:43 AM
50lb_cat's Avatar
Time to hook up a fuel pressure gage and see what the pressure is and run a leak down test. There is a goor article on how to in the DIY section.
Old Apr 21, 2012 | 05:58 AM
pettyfog's Avatar
Note: Pump pressure is different depending on your fuel system. TBI v CPI.
If it dies when hitting a bump, I suspect electrical problem.
Turn key off then on. Do you hear fuel pump? Should run for two seconds, each 'key > on'.
If so, bad connection to pump more likely.
Do you have a tach? Does needle bounce while cranking?
Old Apr 21, 2012 | 10:16 AM
thorrmz's Avatar
thorrmz is on a distinguished road
alot of what is posted on these it dies after awhile always seems to follow the fuel pump but out side of that..... what other if any symptoms have you noticed? skippin idle any odors.. lack of power loss of mpg..
Old Apr 21, 2012 | 11:28 AM
lazer2000's Avatar
lazer2000 is on a distinguished road
'won't turn over' - are you saying the starter motor is not engaging / the car is electrically dead or is it just that the motor doesn't start because e.g. there is no spark/fuel?
My own vehicle once refused to turn over because the fan belt was stuck on a broken alternator - so evidently anything the fan belt runs over could stop an engine from turning over as well.
But what would run 'only when it is cold'- what could start to fail as it warms up and require a 'bump' to stop working?
reddheadnla
Apr 23, 2011 11:08 AM
sk8_dude90
Nov 30, 2010 02:25 AM
Blazer Will
Dec 13, 2009 06:22 PM
redneckwoman
Sep 3, 2009 12:04 PM
TTATE
Aug 11, 2009 07:43 PM
