1993 blazer problems
Old Jan 3, 2009 | 11:47 AM
Gravy_lei's Avatar
Gravy_lei is an unknown quantity at this point
Default 1993 blazer problems
My 1993 chevy s-10 blazer runs fine drives well but the service engine light comes on and you go to stop at a light or something and the truck shuts off any help wit this problem
Old Jan 3, 2009 | 03:12 PM
blazr4.3's Avatar
blazr4.3 is an unknown quantity at this point
Default RE: 1993 blazer problems
Hop on over to a transmission shop, Auto Zone or something similar and get them to put
a little computer on it. That code will tell you whats wrong or real close to it.
Auto Zone doesn't have the good diagnostics reader but in will give you a good roundabout idea of what it is.
Old Jan 3, 2009 | 04:24 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
dont know about you but around here autozone dont have obd1 reader anymore they cant/wont test anything older than 1996, however advance does still test obd1
Old Jan 4, 2009 | 12:56 PM
Gravy_lei's Avatar
There lies the problem nobody has an obd1 reader anymore so I'm shooting in the dark about whats wrong drove it today the SES light came on but it didn't cut off thought it would but it didn't the Truck has 203K miles on it but it still drives like a dream
Old Jan 4, 2009 | 03:36 PM
Why would anyone with an OBD1 vehicle be looking for a OBD1 code reader when it is as close as a paper clip away...?
TroubleCodes.net
Old Jan 12, 2009 | 08:28 AM
tprouty's Avatar
tprouty is an unknown quantity at this point
I had the same issue on mine... while at idle sounded bad...coming to stop needed to keep foot on gas or would die... white smoke coming from exhaust, having the "spider" replaced. (fuel injectors)
Old Jan 12, 2009 | 07:44 PM
Barc's Avatar
Barc is an unknown quantity at this point
I would try to see if you've got a vaccuum leak. Mine had a similar issue after I worked on the 4wd. I must have drained the vaccuum reservoir because it wasn't running well, and if I got the front end on an incline or stopped too hard it would die. Check all of your vaccuum hoses and make sure they're not rotted, cracked, cut or unplugged. That's the quick easy fix; but, hopefully that's it. I've heard that the nipple (for lack of a better term) that's right in the center between the manifold and the firewall is suspect to slipping out of the vaccuum line. Hope it helps!
1993 S10 BLAZER 4X4 CPI
Sep 16, 2012 11:28 AM
freez
Nov 30, 2011 02:11 PM
brdshootr
Sep 30, 2011 08:34 PM
multiplicityz
May 23, 2010 02:14 AM
Gravy_lei
Jan 4, 2009 02:12 PM
