High RPM (3000) all of a sudden
Old Nov 29, 2009 | 10:06 AM
TheMoneyPit's Avatar
TheMoneyPit is on a distinguished road
Default High RPM (3000) all of a sudden
Hello all,
I have a 1995 4.3L vortec 4x4
My trouble started this morning, I went to start the truck and RPM shot up to 3000-3100 with no "check engine" light. I cut the truck off and assumed it may have been stuck throttle cable - not it. Next I checked all visible vacuum hoses and all are on and in pretty decent shape. Next, I hopped on here and searched the forum I found suggestions to check TPS, MAF, and IAC circuits. I do not have a voltage tester handy, so I did the "disconnect" method to let the computer go to defaults. First thing I tried was the TPS, of course the check engine came on immediatly (so I know it's not burned out) and the RPM's only went to 1600-1700 when I did that and showed no signs of going any lower. If I try to put into gear, it slams into R and D, but RPM goes to normal range in those gears.
I have not tried to disconnect the MAF and IAC - honestly don't know where IAC is on this truck. Is the "disconnect" method an accurate way to diagnose without a voltmeter?
Any suggestions are greatly appreciated. Thanks all.
Old Nov 29, 2009 | 10:51 AM
Default fixed it
Not trying to bump this post so soon, but I found the problem and wanted anyone else with this problem to know what it was - for me anyways.
It was a vacuum line i missed - one that goes from the round black ball type of thing on the driver side attached to the hood. There was a vacuum hose that ran from it to the back of the engine that had a hole in it near the engine. I temporarily patched it until I can get to store to get new hose. Also had battery disconnected for about 15 mins while I worked on it to clear computer.
Everything back to normal - idle around 700 again!
Old Nov 29, 2009 | 12:28 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
whats that black ball under the hood used for? why is it there?
Old Nov 29, 2009 | 12:47 PM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
it is used as a reserve for vacuum
Old Feb 17, 2011 | 05:13 PM
dylan88's Avatar
dylan88 is on a distinguished road
where does the line for the back of the motor hook up at? exactly. that is my problem. the line is off and i have no clue where it goes...any helop i need to know asap thanks
Old Feb 17, 2011 | 06:01 PM
That depends on what you are driving...
Old Feb 17, 2011 | 06:11 PM
caditech's Avatar
caditech is on a distinguished road
the "black ball" is used to act as a reserve vaccum canister to prevent your blend doors for your heater box from closing to their default position when the engine is shut off. and as far as routing im not sure but i know its routed somewhere along the bulkhead (firewall)
Old Feb 18, 2011 | 08:31 AM
dshuld's Avatar
dshuld is on a distinguished road
On my 96 the line goes to the same port on the upper intake as the pcv valve. The port is located under my intake tube. The side sticking straight up is the pcv and the smaller is tied in to the three way below the vac reservoir.
fbaker25
Nov 15, 2019 03:41 PM
mcdevin1973
Oct 5, 2014 02:52 PM
fbaker25
Oct 14, 2012 11:49 AM
Aanenson
Feb 1, 2012 11:00 AM
budiblazer
Jun 21, 2006 10:01 PM
