1994-s-10 blazer front wheel hub.
Old May 20, 2012 | 09:33 AM
Team Goofy's Avatar
Team Goofy is on a distinguished road
Default 1994-s-10 blazer front wheel hub.
I have a 94- blazer -4wd. need to replace wheel hub assembly, was looking for some advice on procedure. thanx.
Old May 20, 2012 | 09:39 AM
war00's Avatar
war00 is on a distinguished road
jack up car, place on jack stands, take off wheel 19mm, undo axle nut 36mm, remove brake caliper and bracket, remove rotor, remove 3 bolt holding wheel bearing on and whack with big hammer till it comes loose. assembly is opposite removal.
Old May 20, 2012 | 02:06 PM
50lb_cat's Avatar
A 3 jaw puller makes the job easier to get the hub off. Also, be sure to torque the axle nut to what the maker recommends otherwise it will shorten the life of the hub.
chucksnova
Sep 23, 2011 07:38 AM
Kendo
Mar 12, 2010 11:49 PM
C5Longhorn
14
Mar 30, 2008 09:24 AM
Marcin
Nov 9, 2006 11:31 AM
BigGreenMonster
Aug 24, 2006 01:32 AM
