How do you adjust the idle on a throttle body?
Old Oct 28, 2010 | 08:09 AM
Bigguns72's Avatar
Bigguns72 is on a distinguished road
Default How do you adjust the idle on a throttle body?
Have a 1989 K5 Blazer and the idle is a little high. At icy instersections, when stopped, the rear wheels want to push me through. How does one adjust the idle on these throttle bodied units?
Old Oct 28, 2010 | 08:11 AM
It is controlled by the ECU. I would check to make sure that you do not have any broken/cracked/disconnected vacuum lines and that there isn't a gasket leak between the throttle body and the intake manifold (somewhat common problem).
Old Oct 28, 2010 | 10:45 PM
6.2 man's Avatar
6.2 man is on a distinguished road
Sounds like rear brakes aren't working ?????
Old Oct 28, 2010 | 11:26 PM
69chevelle's Avatar
69chevelle is on a distinguished road
agreed, mine did the same untill i redid my rear brakes...
I actually had to put it in neutral to stop, or 4wd(kept hubs locked in the snow).
Old Oct 29, 2010 | 02:11 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
There is a way to adjust it I will have to search for it and maybe link to another forum if it's ok.
Old Oct 29, 2010 | 02:18 AM
xmradioguy's Avatar
People will argue and say this won't work or you can't do that only the ecm adjusts idle speed, but trust me it does work I have done it to more than 1 tbi and it won't screw anything up. I have done it on my stock 4.3 tbi I have done it on my 5.7 jimmy /holley 670 tbi and lots of others,if you need it I have a pic of where the idle screw is hidden on the tbi's
http://www.thirdgen.org/tpimod2
Attached Thumbnails How do you adjust the idle on a throttle body?-tbi-idle-screw.jpg   How do you adjust the idle on a throttle body?-tbi-idle-cap.jpg
Old Oct 29, 2010 | 05:54 AM
You can change base idle on just about any older setup. However, that is kind of just a bandaid. You haven't really solved the problem...
Old Oct 29, 2010 | 05:12 PM
xmradioguy's Avatar
Well it adjusts the idle speed without the ECM correcting it so yes technically it does solve the problem but like I said some people always argue even if they have never done the procedure.
Old Oct 29, 2010 | 06:52 PM
Assuming there are NO other reasons for the high idle, you would be correct. However, if there is a vacuum leak, adjusting the base idle will not fix the leak.
2000TAHOEMAN
Jan 1, 2011 08:27 PM
jacobbuniger
Dec 17, 2010 03:08 PM
midnightryder
Dec 29, 2009 02:43 PM
er.rigney
Jun 3, 2009 09:16 PM
ivannj
Engine & Internal
Sep 8, 2006 05:46 PM
