4WD Electrical?
Old Feb 20, 2012 | 09:12 AM
BillB1210's Avatar
BillB1210 is on a distinguished road
Default 4WD Electrical?
I replaced the three port vacuum switch on the transfer case and the shift motor on the trnasfer case. I now believe the shifting problem is in the switch or something else.
Is there a relay or control mechanism between the switch and the shift motor? Is there a wiring diagram available for this circuit?
My problem is that the switch lights up as 4WD high, blinks when I shift to 2WD and does nothing when I try for 4WD low range.
Thanks much, it is getting expensive and frustrating. Everything worked a few weeks ago.
Thanks,
Bill
Old Feb 20, 2012 | 06:55 PM
Mag-300's Avatar
Mag-300 is on a distinguished road
What year is this?
I had a friend who had a 2000 that did something similar.
It wound up being the trans fer case was locking.Once he took the motor off he had to turn the t-case with a big flat blade.Once he got it back together he backed it up in 4 wheel low and busted the front differential.
Old Feb 20, 2012 | 11:33 PM
choover82's Avatar
choover82 is on a distinguished road
Ouch, that doesnt sound like a cheap fix for your friend. Id rather have non working 4x4 then a busted front diffy
Old Feb 21, 2012 | 06:43 AM
BillB1210's Avatar
The Blazer is a 1992 code "W". I guess what I'm looking for is an electrical diagram of how this works from the switch to the indexing motor on the transfer case.
The vacuum side works fine, new 3 port switch and the diaphram and cable work freely.
Thanks,
Bill
Old Feb 21, 2012 | 07:33 PM
Mag-300's Avatar
Hope these help out.
Attached Thumbnails 4WD Electrical?-four-wheel-drive-indicators.gif   4WD Electrical?-4x4-electric-shift.gif   4WD Electrical?-4x4-electric-shift-2.gif
Old Feb 22, 2012 | 02:34 PM
BillB1210's Avatar
Mag-300,
Thanks, I will try these.
Bill
Old Feb 22, 2012 | 04:26 PM
Mag-300's Avatar
Your welcome...hope you figure it out.
JoSHN
Sep 14, 2012 04:56 PM
ASCOTTH
Mar 30, 2011 09:40 PM
oneton77
Jul 2, 2010 10:21 AM
Dahlin
Feb 19, 2009 01:53 AM
kikinorcass
Mar 11, 2008 04:23 PM
