4x4 vac.
93LT---- ya answered my post last night. vortec 4x4 vacuum line i found unhooked was bk by dist. so I plugged it in and had cruise again but no 4x so I looked again and found plastic line with rubber elbow on that I hooked to the junction with other lines on it but still notta!!! could i have unhooked somewhere else while I was working bk by distributor? where and what should I chk? i have never had trouble with 4x until i was bk in that area working on dist cap and plug wires HELP 93LT or someone THANK YOU
What type of problem are you having? Trouble with 4Hi, 4Lo, can you hear your solenoid when you press your button, does the button light up, etc.
I would try to keep everything in one thread from here on out. Folks check threads when they bounce to the top.
Maybe you've already done this, but I'd check the vacuum hoses themselves. Mainly the 5/32 vacuum hose running to the vacuum canistor. Look for cracks or worn through spots. If the vacuum line turns your hand black just touching it, it's rotten. The front axle on your vehicle has a vacuum controlled front axle acuator. Should be located under the battery. You'll notice a vacuum line running beyond the vacuum canistor ball, down below your battery. Somewhere along in there, check the connections, hose quality, etc. If you changed your cap and rotor, chances are you pushed on something elsewhere in the compartment as most people have to crawl in there to get back to the cap and rotor.
The 4 lo indicates your transfer case is functioning with your button. This leads me to believe the actuator isn't getting enough vacuum to funciton the actuator, the actuator is bad, or the cable going from the actuator to the front axle is having a problem.
thanks 93LT i will chk some more after work tomorrow if ya can chk this post tomorrow night see if i got anymore Q's you are a big help nother thing is i cant change my preferences on profile as in e-mail, pm's, anything. keeps coming up smthing like your login or e-mail has been chosen please try again anyone have any ideas how i find out bout that?
hello 93LT and everyone. 4x4 working, had vac leak. i guess it was not drawing enough vac. but I am trading tomorrow. getting a 01 blz 64000 mi. cherry. cept i do need to get some aggresive tires. since i do alot of hunting and dont think stock will work, and my uphill IL. driveway!!!!!! I will post pix of 94 s-10 and 01 blz soon as i can. thanks for help to all i will have q's bout this 1 just to find out bout it. ya know what is this and that.. To all a MERRY XMAS and a good new yr thanks again
djkrash
Jan 8, 2008 03:23 PM
MudHawg
Dec 20, 2005 12:56 PM
