85 S10 cranks but won't start
Old Jan 17, 2011 | 10:00 PM
treblaze's Avatar
treblaze is on a distinguished road
Default 85 S10 cranks but won't start
Any help please, I have an 85 s10 blazer 2.8 2wd with no ecm. everything had been running good. went to start one morning and it turns but won't start. got a inline spark tester and tried one plug on each side but no light. replaced cap, rotor,icm,coil,wires and plugs are a few months old. fuel pump works and i can smell the gas coming up the carb. with no computer test, running out of ideas. from what i read you guys are pretty good, any suggestions?
Old Jan 17, 2011 | 10:10 PM
90in87's Avatar
90in87 is on a distinguished road
check timing? and how bout fuel delivery? new fuel filter recently? what kind of crank noise loud and fast or...?
Old Jan 17, 2011 | 10:12 PM
90in87's Avatar
i'm still new to the fixin and troubleshootin, but those are some of the issues that have slowed me down and may be affecting you?
Old Jan 17, 2011 | 10:24 PM
treblaze's Avatar
It does have new fuel filter and new battery so it cranks strong. Haven't done timing check yet. Is the timing something that can change all of a sudden and cause it not to start? Haven't disturbed the distributer position. What else with fuel delivery should i check?
Old Jan 17, 2011 | 10:48 PM
90in87's Avatar
well i'd loosen up distributor turn it a little one way or the other to check that, check that there isnt any leak anywhere and fuel pressure check, also be sure that the distributor is wired properly and firmly in place. make sure all lines click into place as well, its pretty easy to leave them a little loose especially the center
Old Jan 18, 2011 | 10:07 AM
ohsofly's Avatar
Will it start with Ether? Smelling the fuel is not necessarily good, it could mean you are flooding, could be caused by a faulty float in the carb, or a the metering device leaking. Try and see if it fires on Ether when its been sitting for a while. Can you see liquid gas inside the carb, or just vapors? Pull a spark plug and see if its wet with gas when youve been cranking and it wont start.
Old Jan 19, 2011 | 08:53 PM
mxpxpunkrock1987's Avatar
mxpxpunkrock1987 is on a distinguished road
if had no spark check the coil for power if not getting 12 volts there's your problem or either the ignition switch u have to have a source of power to create spark
jfrust64
Feb 11, 2013 01:14 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
sindy1232
Jul 25, 2008 11:59 AM
99whiteblazer
13
Jan 8, 2008 06:45 PM
