86 2.8 idle problem
Old 11-18-2007 | 07:07 PM
swells244's Avatar
swells244 is an unknown quantity at this point
Default 86 2.8 idle problem
My 2.8TBI engine runs fine on the highway but wants to stall at idle .When I run the scan tool on it the O2 sensor shows rich at idle .The idle is about 900 rpm and will cut in and out almost like turning the engine off just for a second.
Any ideas ?
Old 11-18-2007 | 09:13 PM
Hanr3's Avatar
Default RE: 86 2.8 idle problem
It scarb'd correct?
Could be as simple as a minor adjustment.
Although to be honest, its been 20 som years since I messed with a carb in a truck.
Old 11-19-2007 | 05:02 PM
swells244's Avatar
nope not a carb engine it is a TBI engine.
Old 11-20-2007 | 09:58 AM
Sunshine Coaster's Avatar
Sunshine Coaster is an unknown quantity at this point
I would start with checking the fuel injectors...take off the air cleaner and see if theres any dripping from them at idle. Also check your EGR valve, if it's got any carbon build-up on the pintle that would cause it not to close off and to run rough at an idle. Last but not least check the IAC ( idle air control valve) This is what controls the idle speed, not sure how to diagnose it without changing it out though, maybe someone else here knows how.
blazer chris
12-08-2011 09:56 AM
UnknownFish
22
11-14-2011 07:40 AM
Chevrolet.Love
08-19-2011 09:05 PM
97BLAZE4X4
02-07-2010 07:33 PM
Daytripper540
03-29-2007 03:54 PM
Quick Reply: 86 2.8 idle problem
