86 blazer 4X4 fuel pump issues
Old Mar 10, 2010 | 10:37 PM
blazendizz's Avatar
blazendizz is on a distinguished road
there is no silonoid on the pump i just got done changing mine and if the pump is kicking on then its not a relay but if you don't beleive me you can just switch relays they should be both atatched to a metal braket under the hood infront of the driver side one is for fuel and one is for the air so switch them over and try that but i don't think thats your problem. if the pump is working then its probably something else disconnect the fuel line off the fuel filter coming from the pump turn key on and see if gas come out if it does i would think it has something to do with spark and not fuel maybe a new cap and router will do you good
Old Mar 10, 2010 | 10:54 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Only problem is he said he doesn't have any gas coming out with pump running and the line at the TBI off.
Old Mar 10, 2010 | 11:40 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
im putting money on a clogged fuel filter.
Old Mar 10, 2010 | 11:52 PM
Me too. Or at least garbage in the line. But I'll take the filter too. Man it's only a couple of minutes to remove the line.
Old Mar 11, 2010 | 07:33 AM
bobditts's Avatar
if it were me, I would change the fuel filter. In the process though, while I have the filter disconnected, I would put a jumper to the pigtail wire hanging off the fuel pump relay and see if fuel comes out the line where it attaches to the filter. If gas comes out, youve found your problem area.
Old Mar 11, 2010 | 09:09 AM
speedzonwheels's Avatar
speedzonwheels is on a distinguished road
I have changed the fuel pump on an 89' with that TBI system. The pumps usually outright fail on these and won't run at all when they stop producing noise to hear. So I would say the easiest way is to take the fuel filter off and see if gas comes out when you do that, otherwise if you think its a real PITA to do that. Just take a copper rotating cutter and cut the line off on each side of the fuel filter. Buy a new filter with two new ends and some rubber fuel line withe clamps. Total project will take you twenty minutes and probably twenty bucks.
Old Mar 11, 2010 | 06:40 PM
saltwater 35's Avatar
saltwater 35 is on a distinguished road
Well, guys i bought a new fuel filter and began my attem pt to install it after work at 4pm. (BTW Ive worked on Cummins for over 15 yrs and have had chevy small blocks since I was a kid) But this little endaevor wasnt pleasent. I was thinking i could simply drop the filter and have it done in 10 minutes. But NOOOO. First After removing the grimy filthy power steering pump, i began the chore of removing the 8mm bolt that holds the inline fuel filter in place while being devoured by sand gnats. But im not complaining. I get the filter out, and I can easily blow air through it. So I know its not clogged. Now I do a test, and apply 12vdc to the little pigtail next to the fuel pump relay, and i can hear the fuel pump running in the tank, but no fuel is coming out of the fuel line- at all. At this point, i take out a razor knife and cut a hole in the fabric in the back over the fuel pump location, because tommorrow, Im going to saw a big hole in the back of it to acess the pump. There no way in hell im dropping the fuel tank, and if it fails again, I will have a big hole to access the problem area. I install the fuel filter and notice the fuel supply line is steel on on end and rubber fuel line on the other, so this way GM can gouge you for that "special fuel line" at the dealer, if your fuel hose ever ruptures. The return line is the same way. After installin the filter, i begin th mundane chore of tightening the 8mm bolt that holds in the fuel filter, and is purposely pointing towards the rear of the car, to ensure the task is slow and ardous. I then install the power steering pump, just 3 bolts and tighten the bolts and belt. One part I ddint mention earlier is when i used a pair of channel locks and an axe to remove the AC compressor and hoses. it was in the way, anyway. Its at this point im reminded of why i drive a toyota. I opened the hood to my toyota and grabbed the fuel filter and and removed both clamps with a pair of pliers and removed it in less than 10 seconds, without getting any grease on me. Then for ****s and giggles, i held my breath, and reinstalled the filter on my toyota, then shut the hood, and started it, and then exhaled. I craked the top on a busch beer and thought about how i was going to saw open the rear of the blazer to create an acces panel- that should have been put there by the engineers at GM. Taking something simple, and making it hard, a sad fact with american cars nowdays. Tomorrow the fuel pump will go down, and the blaz4er will be moving boats around the yard again. Im starting to understand why the previous owner sold this thing to me for $400 cash. Its got 1 tire that goes flat after about 8 hours, and everyone says i should repair it, but no, its my anti theft system. after using it in the yard, the tire goes flat by the end of the day, and it ensure none of the neighborhood punks will take it for a joy ride. Then i would have to buy another 4x4 for abuseing in the boat yard. they tried to stel it once, and ripped out the stupid alarm system, but it would run for them, lol. I also really love how the fuse panel is hidden way up iside the drivers side firewall behind the brakepedal area, really difficult to access. everything seems difficult on this thing, compared to other vehicle Ive owned.
Old Mar 13, 2010 | 01:28 PM
So I get up early, mark the corners and cut myself an acess panel. I remove the grit and debris from the pump/float assembly and remove the sealing ring to gain acess to the pump. Note picture 12--- the pump is working fine, but the short rubber connection tube has a hole blown through it. At first I think of replacing the pump with the new one i bought, but noticed several variations witht he replacement pump, so I just changed the rubber tube and clamps and reintalled the pump/float assembly. I remember when i was young, I had a 69 Chevelle, and when the feul pump failed, I just had to remove 2 small bolts from the front of the engine to replace the pump. None of this crazyness with an electric motor running inside of your gas tank. Aftr finishing, i turned the key on, waited about 30 secondes for the pump to prime the fuel system and it started on the first try. The inside of the gas tank looked great, the lines are all clear, and the filter was ok. so for everyones notes, if you hear the pump running inthe tank, and youre getting no fuel, at all- its probably the little crappy rubber jumper tube has ruptured- possibly due to the alcohol they are adding to the fuel we use nowdays. Thanks for your inputs, guys!
Attached Thumbnails 86 blazer 4X4 fuel pump issues-p1010012.jpg   86 blazer 4X4 fuel pump issues-p1010003.jpg   86 blazer 4X4 fuel pump issues-p1010004.jpg   86 blazer 4X4 fuel pump issues-p1010006.jpg   86 blazer 4X4 fuel pump issues-p1010007.jpg
Old Mar 13, 2010 | 01:45 PM
The picture with the brake master cylinder, shows the location of the fuel filter, hidden benath the power steering pump, and right next to the exhaust manifold. Really diffult to acess.
Old Jul 6, 2010 | 01:46 PM
farmboy87's Avatar
farmboy87 is on a distinguished road
Default re..
i just dropped the tank in my '87 and the tube could have fell off but your relay could be bad.I'm in the same boat your in.
BouncingRadical
14
Nov 27, 2015 12:30 AM
brian r
Apr 5, 2015 12:23 AM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
