86 blazer, throttle body injector not working!! please help
Old Mar 31, 2010 | 10:26 PM
LO3671's Avatar
LO3671 is on a distinguished road
Question 86 blazer, throttle body injector not working!! please help
i have a 86 chevy blazer with a 4 cylinder single throttle body injected motor. the injector is not working i already change the fuel pump and i am getting good fuel pressure but the injector does not want to kick on.
Old Mar 31, 2010 | 11:21 PM
ohsofly's Avatar
an 86 with TBI??? Sure you dont have a carb on that engine with a dead accelerator pump???
Old Apr 1, 2010 | 05:50 AM
swells244's Avatar
swells244 is an unknown quantity at this point
A 1986 model has TBI. It was the first year.
Old Apr 1, 2010 | 05:52 PM
ohsofly's Avatar
OK cool, when I yanked the engine out of my 85 I could swear it was carb'd...
This is when you want to go invest some cash into some NOID lights (20 bucks you might get some for), and chase the wires for the injector back looking for cracks or pinches. There should be a fuse for the injector that you can check out to. If the wires shorted out it should have popped that fuse on you. Take a look into the harness plug and see if the connectors up inside the plug are still looking good.
Old Apr 3, 2010 | 03:53 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
First thing I would check is if I was getting 12 volts to the injector. Your ECM 1 (10 amp) fuse supplies power straight to the injector via the Red wire. The injector then gets ground through the ECM to pulse. The wire from the injector to the ECM (terminal A5) is Lt Blu. You might try grounding this wire to see if the injector opens.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
blazerowner2011
Aug 2, 2011 07:52 AM
bommaritomike
Nov 19, 2010 06:56 PM
94camaro
Performance & Brainstorming
Dec 15, 2008 02:15 PM
