87 S10 Blazer Lift Gate opening problems
Old Jul 23, 2012 | 04:22 PM
S10BlazerFTW's Avatar
S10BlazerFTW is on a distinguished road
Question 87 S10 Blazer Lift Gate opening problems
On my 87 Blazer, it has the 2 piece rear opening. Top window opens upward, bottom tail-gate comes down. And at the top of the tail-gate, there is a little black turn **** with 2 arms stinking out, and a key hole in the middle. A couple months ago it worked fine. You put the key in, and turn the black part left, it opens the window, then right helps drop down the tail-gate. Well now, the black part just spins around and doesnt "grab" the key hole like it should. Anyone have/had this problem and know how to fix it?
Old Jul 23, 2012 | 04:54 PM
Rottidog's Avatar
You have to open up the gate & see the mechanism. Sounds like it's broken & you should be able to find a new one on rockauto.com. Don't forget to look in the main page here for the monthly discount code.
Old Sep 9, 2012 | 08:46 PM
meatbag's Avatar
meatbag is on a distinguished road
Mine did the same thing once when I turned it too hard one time and "overshot" the internal catch lever thing. I had to remove the inside plastic door panel and some other metal shields to get to the inside of the latch to re-engage the little lever that the black twisty handle engages with.
Does that make any sense?
It is possible however that you simply broke the twisty handle and will need a new one.
Sh*t happens, and nothing lasts forever.
Rock Auto is your best bet for a new one.
GOOD LUCK!
Old Sep 9, 2012 | 09:51 PM
neo71665's Avatar
Any parts store should have it. I replaced all the outside locks in my 87 years back and got them from autozone (before my personal boycott of them).
Dxb105
Feb 28, 2014 04:58 PM
BigEffingHammer
Oct 1, 2011 06:02 PM
futuredoc
Jun 3, 2011 08:09 PM
JODYM
Feb 1, 2009 12:44 PM
web road runner
Nov 13, 2007 10:15 AM
