2000 Blazer Interior Lights won't work when opening door
Old Jan 27, 2009 | 04:15 PM
JODYM's Avatar
JODYM is an unknown quantity at this point
Default 2000 Blazer Interior Lights won't work when opening door
Interior lights will work when you turn the switch on in the cab but will not work whe you open the driver's side door or passenger side door It is a 2 door LS model Any help or suggestions would be great Thanks
Old Jan 27, 2009 | 04:36 PM
flyinquack's Avatar
flyinquack is an unknown quantity at this point
Default RE: 2000 Blazer Interior Lights won't work when opening door
not that i claim to know much about cars, but did you try that little dome override push switch? when its out i believe the interior lights come on when a door is open.
Old Jan 27, 2009 | 04:55 PM
mdehoogh's Avatar
ORIGINAL: flyinquack
That would be my guess as well. The dome override button doesn't indicate very well whether its depressed or not. It seems to stick out the same amount regardless of if its in or not.
You could also check to make sure the switches in the doors are functioning correctly. If they're stuck in, that would make the switch think the door is still closed.
Old Jan 27, 2009 | 07:12 PM
JODYM's Avatar
Thanks for the info. the override button was sticking, not allowing it to come out all the way Thanksagain Jody
Old Feb 1, 2009 | 12:44 PM
bamablazer57's Avatar
bamablazer57 is an unknown quantity at this point
thats whats wrong with mine
habafab
Dec 14, 2014 10:56 AM
Sean Perkins
Sep 11, 2012 09:32 PM
futuredoc
Jun 3, 2011 08:09 PM
stlarry
Nov 4, 2009 10:51 AM
toyfan1
Aug 21, 2008 07:05 AM
