87 s10 blazer prob
Old Jun 3, 2012 | 12:17 PM
STREET2TRAIL's Avatar
STREET2TRAIL is on a distinguished road
Default 87 s10 blazer prob
ok so i bought a blazer with 2putt8 in it ran good then i took the truck off the trailer and it sat for a few weeks went to start it and it cranked over strong would not fire. i noticed i did not hear fuel pump so i went to change it, tested it it was good, then checked fuses found ecmb fuse was dead changed it to only have it pop. found that problem at the oil presure switch wires.
now i have no pump when i turn the key but works when i put 12v to it. changed relay looked for fuses but no luck.
what could it be????
any help would be great
thanks
Old Jun 3, 2012 | 03:12 PM
maddie's dad's Avatar
maddie's dad is on a distinguished road
what is 2putt8? Recheck your oil pressure switch wires and fuel pump relay. I'm not sure how similar your 87 is to my 93. Let me do some research, and I'll get back to you.
Old Jun 3, 2012 | 03:16 PM
2putt8 =slow 2.8l
checked realay seems to work not sure on how to bypass switch would like to do that
Old Jun 4, 2012 | 03:39 AM
neo71665's Avatar
Fix the problem at the "oil switch" wires.
Old Jun 9, 2012 | 09:00 AM
rewired the wires still nothing relay is good fuel pump is good all fuses are good now im at loss gonna try the oil pres. switch and go from there
Old Jun 12, 2012 | 10:22 PM
:icon_brick s:
thanks
this things about to make me burn it to the ground replaced oil pres switch and wiring fuses and nothin any thing else it could be
thanx
LSpoweredStepside
Sep 30, 2013 09:22 PM
kashmoney07
Nov 28, 2009 04:49 PM
muleman
May 26, 2008 01:11 PM
gsdmix
Mar 15, 2008 06:06 PM
heitger0003
Apr 17, 2007 03:33 PM
