'89 4.3 ltr S10 Blazer problem
Old Aug 28, 2009 | 05:26 PM
Theunforgiven's Avatar
Theunforgiven is on a distinguished road
Default '89 4.3 ltr S10 Blazer problem
Hey everybody, name's Kevin. This is my first post here. Recently, I've been having a problem with my blazer where when I start it up it will sputter then cut off, or other times I will get it running and when I begin to come to a stop the engine will die on me. To me it sounds like it might be a fueling problem, but I don't know a heck of a lot about these things. So does anyone have any idea what the problem might be? Thanks in advance for any replies!
Old Aug 28, 2009 | 06:43 PM
mr.vls's Avatar
Could be a faulty Idle Air Control (IAC), especially if it does it with the car cold or warmed up. Could also be a leaking egr valve. The egr should be closed when the engine is cold and also when at idle. If it is leaking by it will cause rough idle and maybe even stalling.
Old Aug 28, 2009 | 11:42 PM
Sounds like you may have a stuck EGR valve. When was the last time the engine was tuned up (spark plugs, cap, rotor, and wires)?
Old Sep 5, 2009 | 01:37 AM
cjmor1804's Avatar
cjmor1804 is on a distinguished road
If you had any of those problems, wouldn't a check engine light come on??
Old Sep 5, 2009 | 04:15 PM
mr.vls's Avatar
EGR if it is leaking will not through a code, If the EGR Solenoid fails or does not respond to the ECM it will through a code. Same with the IAC if it is responding to the ECM it will not through a code but could still be faulty. Not all faults create codes.
Old Sep 5, 2009 | 05:50 PM
cjmor1804's Avatar
good to know... when mine was reading the EGR code, i changed the "valve", and the code went away, i believe it was not opening all the way. was this triggering the "solenoid" as faulty because it couldn't open/close it? changing this did help in start up/idle and it quit stalling when it was cold, but im still having problems with acceleration (mis-fire/back-fire) occasionally.
ChristopherMoser
Mar 4, 2015 07:42 PM
94BlazerGirl
Aug 28, 2014 06:14 PM
daddyrabit
Apr 21, 2013 08:23 AM
Melrock83
Jul 12, 2012 03:15 PM
Shade
May 17, 2007 05:16 PM
