91 blazer 4.3L 4x4 stick starter removel
Old Sep 11, 2010 | 02:56 PM
jsmith2260's Avatar
jsmith2260 is on a distinguished road
Default 91 blazer 4.3L 4x4 stick starter removel
Sorry in advance... i am a nubbie. does anyone have a trick to get the starter out of this thing?
Old Sep 11, 2010 | 06:40 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
alot of patience , it comes out only one way. I have spent an hour with no success and had to walk away and when i came back it practicly fell out .
Old Sep 12, 2010 | 11:20 AM
jsmith2260's Avatar
thank you i will see what i can do.
Old Sep 15, 2010 | 11:27 PM
924dr4wdw/horns's Avatar
924dr4wdw/horns is on a distinguished road
the book is gonna tell u to unbolt the whole crossmember. dont do that take a drill and drill out a hole in the aluminum bell housing just big enough to get that worm gear out and urr golden starter will go in and out like nothing
Old Sep 25, 2010 | 11:11 AM
nfsroadsta2786's Avatar
nfsroadsta2786 is on a distinguished road
its been a while since i got under my truck but what i did was loosen the starters 2 bolts then the little cover right under the flywheel, once that was done the bolts from the started was removed completely n the starter was pushed a little towards the front of the engine n up towards the exhaust manifold, twisted @ an angle n it came out make sure u disconnect the cables attached to the starter when u loosen the starter enough so that u can angle it
Old Sep 26, 2010 | 10:03 PM
jsmith2260's Avatar
i've tried everything and i cant get it out i think that i will have to remove the motor mount but i dont think it will go out going forward either.
Old Oct 7, 2010 | 02:06 PM
jsmith2260's Avatar
i ended up haveing to pull the passanger motormount bolt and then jack up the motor to get enough clearance to get the thing in and out. once i did that it came right out and went right in. thanks for all the help
Old Oct 7, 2010 | 08:07 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
You may have to move the flywheel cover which to get to all the bolts you may have to remove the slip-shaft....good luck-fun job sometimes....Jerry
Cidium
Mar 10, 2011 02:50 PM
tony991
May 14, 2010 03:17 AM
kevin turner
Mar 3, 2010 08:01 AM
tony991
Dec 17, 2009 09:38 AM
tony991
Aug 11, 2009 08:40 PM
