'91 S10 4.3L runs rough
I have a '91 S10 Blazer with the 4.3L engine. Sometimes when starting it acts like it is running very rich and stumbles. If I rev the engine a couple times, or drive briefly in low gear and take my foot off the accelerator it will settle down and run well.
It also does this rough idle if I drive at high throttle for a while, then stop.
I have replaced the PCV valve (although the old one did not look bad).
Any other ideas? Clean the MAF? Others?
The car gets around 17 mpg with mixed driving.
Thanks in advance.
Thanks in advance.
You do not have a MAF sensor so that is out.
I would clean the EGR valve. If this is leaking past, it can cause rough idle and an overly rich condition.
Thanks. I will check it out.
Mark
Mark
Where exaclty is the EGR valve on the first gen's ? Mines a '94, Im just curious.
coffen
12-25-2013 09:09 PM
bam_9_9_9
49
12-30-2012 08:42 PM
zakm0n
01-10-2011 11:42 AM
sword2269
09-09-2009 07:33 PM
