93 S-10 Blazer Cranks but won't start
Old Jan 16, 2015 | 11:58 AM
GodzillaBugg's Avatar
GodzillaBugg is on a distinguished road
Default 93 S-10 Blazer Cranks but won't start
Hello everyone! I just spent the last hour or so going through the threads on here to see if there was someone else that had the same problem as I am having & fixed it but it seems like there is always a slight difference between their problem and my own and those small differences make a world of difference in some cases. (Basically this is a long winded apology if I am asking the same question that has been asked a thousand times)
So I have a 93 S-10 Blazer 4wd 4.3l Vortec VIN W with approx. 111k miles that my parents actually own but is my only means of transportation. One day I dropped off my grandma and as I was going through my parking lot it just died. It cranks but won't turn over - it seems like it wants to but just can't get there. I have replaced the fuel filter, plugs, distributor cap & rotor as well as the coolant temp sensor. I can hear the fuel pump when I turn the key. There are no codes because the battery has been disconnected for several days in a row and as far as my understanding goes the computer clears the stored codes after that long.
Someone made a mention about the locktronics antitheft device that is installed from before we bought it. Could this be an issue? The device is a little key fob thing that has "gold fingers" on the end that you plug into a slit under the steering wheel next to the place you plug in the code reader. When I say gold fingers I mean like a Nintendo game cartridge has on it.
I also removed the stereo because I believed that it was causing electrical issues. I believed this because when I pressed a button to save a radio station on it the whole vehicle reacted. It is an aftermarket stereo that was installed with a wiring harness by my step-dad years ago.
Any ideas on what I can check or try next would be super helpful because I am getting tired of walking to keep important appointments and I am about ready to blow the stupid thing up. To make it more interesting, I am also on a very, very restricted budget.
Thanks in advance!!
Old Jan 17, 2015 | 03:49 PM
ussexplorer's Avatar
ussexplorer is on a distinguished road
Default okay
I take it you checked for fuel pressure and spark. So if you did. Did you check your computer to flip the code of 12. I think it is 12 for okay. To make sure your computer is happy. Can't Remember what you jump though to get it to flash the codes. c / d or something like that on the obd connector.
TTFN,
Joshy
Old Jan 18, 2015 | 09:55 PM
I'm not sure I understand what you mean with the code of 12 thing. I've never heard of it before - if you don't mind could you explain it to me? I really appreciate it. Thanks in Advance
Old Jan 19, 2015 | 06:12 PM
richphotos's Avatar
Old Jan 20, 2015 | 04:23 PM
GoldOlds94's Avatar
GoldOlds94 is on a distinguished road
Your EGR valve might be clogged with carbon build up. Or could be fuel injector unit could have a leak or problem.
Old Jan 25, 2015 | 04:35 PM
richphotos's Avatar
Code 12 just means the system is working.
If there were no other codes following code 12, there is not an issue with something the computer monitors.
I would suggest doing a fuel pressure test and leak down test.
Pressure should be KOEO (key on engine off) 60-62psi and should not drop below 55psi in 10 minutes.
Old Jan 27, 2015 | 09:40 AM
air1force1's Avatar
air1force1 is on a distinguished road
Remove a plug wire and verify you have spark. If you do have an assistant add a spray of starter fluid. If it tries to start, you will know your issue is on the fuel side of the equation.
Old Jan 27, 2015 | 08:00 PM
project85's Avatar
project85 is on a distinguished road
I had the same problem last week with my '85. Upon further investigation I figured out the air filter was completely black! Apparently the guy I just bought it from forgot you need fuel and AIR for a carb to run properly haha
Old Jan 27, 2015 | 08:50 PM
SnyderJ68's Avatar
SnyderJ68 is on a distinguished road
What about the distributor itself have you thought to check that? Perhaps you dirtied up the cam position sensor while replacing rotor and cap
Old Mar 30, 2015 | 09:30 AM
Sorry that it has been so long since I was here last - life got crazy for a minute
Anyhow, I don't have the means to do a fuel pressure test unfortunately. I was told that the anti theft system (loctronics) could possibly be the problem so I ordered a bypass plug from the business that services that brand of devices. Finally got it in the mail, plugged it in and nothing changed. I just replaced the ignition coil last night and now instead of cranking it just clicks. I have no idea what happened. Could replacing the coil have done this? Should I put the old one back in?
Rhodes19
48
Feb 15, 2013 09:46 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
jdbrown66
Nov 19, 2008 03:57 PM
sindy1232
Jul 25, 2008 11:59 AM
