93 S10 Blazer A/C blower not running
Old Jun 15, 2010 | 10:56 PM
sublime167's Avatar
sublime167 is on a distinguished road
Default 93 S10 Blazer A/C blower not running
Hey guys, I'm trying to fix the AC blower on my fiancee's Blazer but I seem to be getting no where. So far I've swapped the blower motor, resister and relay. What else am I missing? Symptoms are the AC condenser runs as I can feel a little cold air coming through the vents, but the motor simply doesn't run on any setting.
Thanks for the help
Old Jun 16, 2010 | 12:43 PM
abig84's Avatar
The actual control switch itself on the dash may be broke
Old Jun 17, 2010 | 11:58 AM
sublime167's Avatar
Thanks I'll give it a look. I'm just hoping I don't have to rip up the entire dash to get to it.
Old Dec 14, 2010 | 10:02 AM
clevelandtrucks20's Avatar
clevelandtrucks20 is on a distinguished road
im having the same problem now please let me know if you had to take the whole dash apart
Old Dec 14, 2010 | 10:28 AM
Kainon's Avatar
Kainon is on a distinguished road
typically dont have to rip the entire dash, just trim around the ac/radio controls, then 2 screws I think to remove the AC/Heat controls
Old Dec 28, 2010 | 04:23 AM
mikede123's Avatar
mikede123 is on a distinguished road
There is a ground wire on the blower motor, make sure you hook it back up in the same spot. Make sure it has a good ground.
Old Dec 28, 2010 | 07:15 PM
bowtie-72's Avatar
bowtie-72 is on a distinguished road
Yes, there are 2 screws under the heater control pod. If you have power mirrors, you will have to remove the 2 screws that hold that switch in place and let it hang loose.
Then pull the pod down and out. You will have just enough room to get to the switch on top. Don`t forget to pull the little **** straight off first. Then you can unplug the 4 wire connector to get to the 2 screws that hold it in. The one on the bottom is not easy to get back in. Have a magnet handy to retrieve it when it falls! Good luck.
Old Dec 31, 2010 | 08:56 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Have you checked the purple wire that goes to the blower for power? I'd start there and work backwards. The relay is kinda interesting on how it's hooked up but you should have some power to the motor regardless of switch position. Voltmeter real handy here. By the way, on HI the power doesn't run through the resistor.
maxvamp
Oct 31, 2020 08:19 AM
ksimpson
14
Oct 7, 2013 05:25 AM
mitchiemitch422
Sep 10, 2011 01:52 AM
fitztool
Dec 9, 2010 06:50 AM
91blazermaniac
Jan 4, 2009 07:44 PM
