94 Blazer bad miss
Old Jun 22, 2010 | 09:04 PM
RaVxX's Avatar
RaVxX is on a distinguished road
Default 94 Blazer bad miss
So I have a 94 Blazer.. and I was jumping batteries, but when i jumped then, i got the termals mixed up like a dumbie , motor was running, it arced and now i have a bad miss in it, idles fine, starts fine, checked the fuseable links near the battery power flowing thru them, you guys think it might of toasted the main computer ? and where is that located ?
Old Jun 22, 2010 | 11:31 PM
Hanr3's Avatar
engine computer is located under the hood, typically on top of the passengers side fender well.
I suspect you toasted the alterator, take it in to an autoparts store and have it tested for free.
While your there, have them test the ICM too. It controls spark timing to engine timing.
After that, its a chase the electrical around the engine. Distributor, wires, plugs, codes, cables, etc.
FYI, you can use a battery to weld two pieces of steel together in an emergency, it'll toast wires and sensative electrical components in half a heartbeat.
Old Jun 24, 2010 | 03:38 PM
rusty91's Avatar
rusty91 is an unknown quantity at this point
computer on the 1st gen is behind the glove box you can get to it from the floor on the passenger side floor it is held in by a nut then slides out if you look on the passengerside fire wall you can see the wiringharness going inside the truck
Pcoleman
Nov 29, 2014 04:54 AM
ussexplorer
Sep 27, 2013 03:38 PM
brandenburgt
Jun 15, 2011 06:06 PM
TSEJEEPERS
May 24, 2010 10:28 PM
blazinblaza
Apr 19, 2010 01:56 PM
