94 blazer "W" fuel system
Old Jul 25, 2010 | 10:28 AM
meworrynot's Avatar
meworrynot is on a distinguished road
Default 94 blazer "W" fuel system
I have replaced the pump and sending unit. I opened up the plenum and am going to change the CPI, "nut kit", and regulator. Is it a good idea to remove the intake to clean it well and replace intake gaskets? It seems to have "normal" oil in it, no pooling, just coated inside. I like to do things once, and don't want to have to do intake gaskets later. Thanks for any help.
Pete in Texas
Old Jul 25, 2010 | 12:33 PM
It would be a good time to replace the LIM gaskets. You'll already be 75% of the way there once you remove the old CPI & 'nut kit'. Put some thread sealant on the LIM bolts to cut down on a bit of the oil intrusion into the LIM.
Also, if you are replacing the CPI spider, it will come with a new regulator so you don't have to buy a second one.
Old Jul 25, 2010 | 12:42 PM
meworrynot's Avatar
Thanks, I would have ordered a regulator too....
Pete in Texas
Old Jul 25, 2010 | 11:55 PM
mosfetpioneer's Avatar
mosfetpioneer is an unknown quantity at this point
not to piggy back onto your thread but where are you getting your cpi unit and how much are you paying?
Old Jul 26, 2010 | 07:35 PM
meworrynot's Avatar
I found it at advanced auto for $293.99. It's a "BWD" brand. Also they have the hose kit for $55.89.
Pete in Texas
Old Jul 27, 2010 | 01:00 AM
hmmm not too bad I was calling around and I was told around 400 so the junk yards I called they said they couldnt get them but when they do its around 200 lol
Old Jul 27, 2010 | 06:10 AM
meworrynot's Avatar
Wow, I found it at NAPA for about 400. I think I would spend the extra for new though, this part seems to be a common failure, so used will fail at som point. Good luck in your search.
Pete in Texas
Old Aug 1, 2010 | 09:48 PM
meworrynot's Avatar
I replaced the cpi and "nut kit" yesterday, also the two relays on the firewall. Truck runs great now. I didn't mess with the intake gaskets, there were no signs of leaks. Thanks to all for the help.
Pete in Texas
ComputerNerdBD
Feb 28, 2010 11:30 AM
shibbershabber
Feb 22, 2010 10:07 PM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
