94 s10 no fuel
Old Mar 1, 2012 | 12:12 AM
des plaines blazer's Avatar
des plaines blazer is on a distinguished road
Unhappy 94 s10 no fuel
when i turn on ignition my fuel pump does not get power i dont hear the whinning noise car does not start i did replace pump 4years ago my chiltons old school book says to look for a fuse in engine compartment i looked in glove box no fuses i cant find fuse im at wits end the is a project ive been working on just rebuilt trans/transfercase / any sugestions thanks.
Old Mar 2, 2012 | 11:53 AM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
I have a hard time hearing my pump anyways and it works. Take the sensor off the top of the plenum, it's 2 hex screws and look into the intake and see if there is fuel, or it smells like fuel, or one sice is clean and shinny and the other dirty. Try searching spider injector in this forum because 9 times out of 10 the injector regulator is bad. Otherwise your you pump is probably bad and just to double check you can get a fuel pressure guage with a schrader attachment and make sure your getting fuel to the rail at all. harbor freight has then for $20.
Old Mar 2, 2012 | 04:36 PM
workshop4ever's Avatar
workshop4ever is an unknown quantity at this point
I would check voltage at the pump, to see if the pump is just shot. Then, check the fuel relay (should be under the hood someplace). After that, see if energizing the "pump test wire" forces the pump to run. There should be a single-wire connector hanging in your engine bay that is for this purpose.
Old Mar 3, 2012 | 05:04 PM
thanks for your replies this is a great website i did find out my pump whent out keep trail blazin
Big Eazy
Apr 27, 2013 12:48 PM
jfrust64
Jul 15, 2012 06:41 PM
95jblaze
Aug 27, 2011 03:46 PM
ricky
Jul 22, 2010 08:04 PM
1994BlazerS10
Mar 3, 2010 08:52 AM
