94 S10 transfer case cable bushings
Old Oct 19, 2020 | 10:07 AM
marktaff's Avatar
marktaff is on a distinguished road
Default 94 S10 transfer case cable bushings
Hi all. Been having trouble finding the correct bushings; hope you guys can help. 1994 Chevy S10 pickup, extended cab, 4wd, 4.3L V6, VIN Z, automatic transmission.
The truck has manual 4WD floor shifter, with a New Process 231 transfer case. The cable that runs from the shifter to the transfer case is missing the little plastic bushings at both ends. I've tried two different Dorman products, and one from a Jeep (a vendor, bushingfix.com, said the truck uses the same bushings as a Mopar Jeep), but nothing fits. The parts are always too large to fit in the cable ends and over the pins.
Any help would be greatly appreciated. Thanks!
cable at shifter
cable at transfer case
Dimensions in inches.
Shifter end
ID 0.348
Lip OD 0.434
Outer width 0.250
Lip depth 0.067
Pin diam 0.249
Pin groove 0.193
Transfer case end
ID 0.372
Lip OD 0.495
Outer width 0.252
Lip depth 0.050
Pin diam 0.251
Pin groove 0.205
Old Oct 19, 2020 | 03:32 PM
Do you have access to a lathe and know how to use it or know somebody who does?
That would be my fix.
Old Oct 19, 2020 | 05:28 PM
eshaw's Avatar
Check with Grainger. At one time they had a cable that could be used for a transfer case. They may have bushings that'll work.
Old Oct 20, 2020 | 09:33 AM
marktaff's Avatar
Sadly, nope.
Old Oct 20, 2020 | 09:35 AM
marktaff's Avatar
Good idea. I'll see what I can find. Does anyone have a photo of what the original bushings look like?
tmsbuic
Jan 2, 2020 12:49 PM
BLAZE1999
Mar 25, 2017 04:24 PM
hardyboy
Mar 23, 2011 08:04 PM
redbug2
Sep 14, 2010 04:14 AM
nate7493
Sep 3, 2009 04:52 PM
